extra fuel pump\booster pump.
Old Feb 6, 2003 | 07:12 PM
breathment's Avatar
i would usualy do a search on this topic but..
would a extra fuel pump added inline after the stock pump help the stock pump to last longer, especialy if i was increasing the fuel pressure? or is it jsut a waste?
Old Feb 6, 2003 | 08:05 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
unless you have a WHOLE lot of power from your NA motor or you have a power adder, you don't need a second pump. as it is your stock pump pushes more fuel than you're using and it just gets sent back by the pressure regulator
Old Feb 6, 2003 | 08:37 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Ukraine has it right. Unless you have a power adder you won't need it. If you feel the stock one might go anytime or it isn't "up to par" then I would go ahead and remove and replace! Maybe go aftermarket if its worth it to you in the long run. But the stock pumps are efficient pieces.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
