RPM monster
Old Feb 11, 2003 | 08:12 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
RPM monster
how many rpm can a stock lower end and pistons take? ive got a 2year old 350 GM crate motor that is a stock replacement type with 4 bolt mains, 1 peice rear main seal non-roller engine.
Old Feb 11, 2003 | 09:14 PM
xxwarrior36xx's Avatar
my friend has a stock 305 out of our cars and it handles 6,000 no prob. I would think it would have similar internals. I would say after that you are lookin to break stuff
Old Feb 11, 2003 | 10:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
About 6500 max!
Old Feb 11, 2003 | 10:23 PM
laiky's Avatar
my bro's 84 L69 305 has seen 7000 rpm many times it has sustained at least 6500. To be safe no more than 6000 sustained maybe 6500 momentarily. If you not making big power, or running a lot of camshaft lift its not quite as bad. I keep my 383 under 6000. Long stroke, plenty of power and high lift hyd roller are more likely to fail than 200 horse, shorter stroke and low lift
Old Feb 11, 2003 | 10:29 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I take mine up to 6400 all the time. Its not the strongest bottom end in the world but they suit it just fine. I'd worry more about the valve float problem you'll be having at that high of an engine speed .
Old Feb 11, 2003 | 10:44 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
depends on if a 305 or 350.....in a 305 the max rpm for a cast stock crank is 6034 rpm.....exceeding that and your asking for touble..i spun a bearing and broke a rod because of overrevving
Old Feb 11, 2003 | 10:51 PM
laiky's Avatar
Elephantismo
Feb 13, 2019 12:51 AM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
