heads/casting numbers
Old Feb 11, 2003 | 10:25 PM
chymos's Avatar
ok, this has probably been asked a million times, but search is broken
what casting numbers should I look for for a 350, from best to worst, and where do the various aftermarket heads fit in the best-to-worst listing?
Old Feb 11, 2003 | 11:12 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: heads/casting numbers
I will just touch on the relatively modern heads dating from the 80s onward.
The nicest factory castings that have a reasonable size combustion chamber and do not need milling are the 083 L98 castings. There are aluminum Corvette castings of this model, as well.
The nicest that will require a specific manifold are the Vortec castings. Thus they actually cost at least $200 extra.
The cheapest are the 305 castings, the 081, 416 and 601 castings, which can be had at the wrecker in good shape for $25 to $50.
You can port and polish both the L98 and the 305 castings to outflow the Vortecs. It will require enlarging the intake valve on the 305 castings but that is not terribly expensive. Follow the link at the end of my sig for a free how-to on the subject
Old Feb 12, 2003 | 06:11 PM
chymos's Avatar
ok......how do the L98 and 305 castings compare to the Pro Action version of the Vortechs, assuming all are ported and polished?
Old Feb 12, 2003 | 06:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
They don't even compare the Pro Vortecs are much better.
Old Feb 12, 2003 | 06:32 PM
chymos's Avatar
That sounds about how I thought. Thanks
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
