Can I use balancer puller for power steering pulley?
Old Feb 12, 2003 | 10:27 PM
Scott C's Avatar
I have a harmonic balancer remover and was wondering if I can use it to remove my power steering pulley. If not, what type of pulley puller should I use? Where to get one?
Old Feb 12, 2003 | 10:49 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I tried to use a regular puller to remove the p.s. pulley. I had no luck and I tried for a couple hours.
The puller I wound up using was a special one with a two piece collar that clipped onto the groove on the front of the pulley. It took an incredible amount of force to remove it- it galled the shaft on old pump. I never would have gotten it if I didn't have the right tool. It is off a 100,000 mile motor so it is older, but dang, it was tight.
Don't try to pull on the outer radius of the pulley- you can bend or break it.
Best-
S-D
Might be able to rent one from a parts store, maybe. I have a firiend who is a mechanic, so it was no problem for me.
Also remember not to hammer the pulley on the new pump. Use the supplied tool (usually comes with one- it is just a hard bolt, washer and two nuts). If you hammer it on it will blow the seals and wreck the pump.
Old Feb 12, 2003 | 10:58 PM
llvll4l2c91350's Avatar
I never understood why they press a P/S pulley to the pump instead of just bolting it on. Not just GM but other makers as well.
Old Feb 12, 2003 | 11:36 PM
ronterry's Avatar
Car: '94 Corvette
You'll bend the hell out the pulley if yout not lucky with a regular puller. I have an old PS pulley in my garage that holds testiment to that fact.
You have to have that collar (ie power steering puller), cause all the force is applied at the center, and not the outside of the pulley.
Ron
Old Feb 13, 2003 | 12:55 AM
Scott C's Avatar
Thanks! Glad I asked
Old Feb 13, 2003 | 07:09 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you can pick a proper puller up at pratically any auto parts store for under 10 bucks, good investment and defently cheaper then a new pulley after ya bend the crap outa urs hehe
Old Feb 13, 2003 | 12:04 PM
Vader's Avatar
That same PS pump sheave puller is used for removing alternator sheaves on many vehicles. It's worth having if you plan to do your own repairs.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
theshackle
Aug 22, 2015 06:52 PM
