Can anyone identify this ring gear?
Old Feb 13, 2003 | 11:23 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Its from an older 10 bolt, the ones used in 2nd gen f-bodys and olders nova's etc.. 3GM 3988577 11 41 7 78 is stamped on it.
Old Feb 13, 2003 | 11:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like a 8½" 10-bolt 3.73 (41/11 = 3.73), stock Z28 gear among others
pretty useless unless you have the pinion that goes with it
Old Feb 13, 2003 | 11:38 AM
89RsPower!'s Avatar
yep have the pinion gear as well, its the origonal gear set from my 73 nova ss which should be 373's but i wanted to double check.. doubt i'll be using it any time soon though.. i was just cleaning the carrier up and i noticed that where one of the locks bolts goes through the pinion shaft it looks as if who ever removed it had a tough time getting it out as it looks like the bolt may have been ceased and broke away the bottom part where the treads should be for the bolt to go into.. would it be possible to tap it below there and use a longer bolt to hold the pinion shaft in or should i start looking for a new carrier?
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
angel2794
Sep 8, 2015 06:22 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
