voltage regulator question
There are two things you can do to test teh regulator. You can meter the output voltage under various loads. A battery load tester can be very helpful when doing this, but you can also use the vehicle accessories to load the system.
If the alternator output voltage remains relatively steady under varying loads, teh regulator is at least attempting to maintain a steady output voltage.
Another thing you can do to test the alternator more than the regulator, is to shunt the regulator and test alternator maximum output. You can do this by shorting the test terminal on the rear of the alternator while metering output voltage. Only do this briefly, since hte voltage will probably reach around +18.
mdtoren
Aug 16, 2015 05:45 PM
