stumbling prob
Old Feb 13, 2003 | 10:27 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
stumbling prob
stumbling prob
would an iac cause stumbling problems while driving or just while it is at idle? what would cause my car to start and then die in like 2 seconds EVERYTIME i start it, unless i give it gas, then it stays running. it cuts out wile driving too, i just cant figure it out.
Old Feb 13, 2003 | 11:29 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
3 things to check
1. TPS Voltage - it should be 0.54VDC +/- 0.01 or such
2. Remove and clean the IAC valve
3. Check your timing
Old Feb 14, 2003 | 04:18 PM
bubbz89's Avatar
Car: 1990 RS
tps is fine, my buddy is going to bring his snap-on scanner to work monday for me. how do i check for vacuum leaks? thanks
Old Feb 14, 2003 | 05:07 PM
91Z28-350's Avatar
it's kind of a multiple pass method
1) visually check all hoses, clamps, etc. and repair/replace as necessary.
2) use something flammable, like a propane torch (unlit), and go over gaskets. If things smooth out when running over a particular gasket, you've found your leak.
Old Feb 15, 2003 | 11:49 PM
bubbz89's Avatar
Car: 1990 RS
would a vacuum leak casue probs all the time, because sometimes my car runs like it should. when i drive my car, and it runs fine, then i park it for 20 minutes or so, and get back in it, thats when the prob gets worse. it bucks like crazy then. i just cant figure it out.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
