my tires squeek when i downshift.
Old Feb 16, 2003 | 02:42 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
ok, lets say im driving 50 KPH, and iim in 3rd, if i downshift to 2nd and just let off the clitch completely, my tires like squeek really bad, like when you lay a patch, thats what it sounds like.. what would cause this?
Old Feb 16, 2003 | 02:51 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Umm whenver your tires squeek it is a loss of traction.. Get some stickier tires
Kat
Old Feb 16, 2003 | 03:18 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
probably becasue your downshifting and the car is moving too fast for the gear your downshifting into so for a brief second the tires lock up when you shift down a gear..
Old Feb 16, 2003 | 10:29 PM
xxwarrior36xx's Avatar
OUCH
Don't do that. You need to match the revs on the lower gear before you put it in gear. Your taking the car runnning at 2,000 rpm's and jamming it up to 3200. Now your rear try's to catch up and can't so it squels the tires. This is not good for it. Before you downshift it into gear, hit the gas pedal a bit to get the RPM's up higher so it is less of a shock
Old Feb 17, 2003 | 12:40 AM
laiky's Avatar
See above post. if that doesn't help get better tires, or an auto.
Old Feb 17, 2003 | 11:25 AM
84silverbirdSE's Avatar
Car: '79 T/A and '84 T/A
Engine: 455 buick and 305 chevy
Transmission: TH400 and T-5
Yeh man go easy on her. You can only beat her so much till she blows.
Old Feb 17, 2003 | 11:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well sometime you HAVE to beat on her . . .
sorry i had to.
but yeah , be nice, try to match the revs when you downshift, you will also notice that braking is much smother if you match the revs up too, there is alot less body movement when you do.
Old Feb 17, 2003 | 06:38 PM
Car: 1984 Z28
i never knew, or really thought, that you should rev it up a bit when downshifting.. it makes sense now that i think about it, but it was kinda cool when it happend!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
