NON Vortec intake on Vortec heads??
Old Feb 17, 2003 | 06:31 PM
hotrod18_69's Avatar
Car: 1997 Camaro Z28
Axle/Gears: Stock 10 with 4:10's
Ok i have a set of Vortec heads and can get an Edelbrock Air-gap intake for 100bucks. Well i noticed in summit mag. They have two one for Vortec and one for non Vortec. Whats the difference? I looked up the part # and its the non vortec one. Can i use it and be ok?
Thanks Brad
Old Feb 17, 2003 | 06:40 PM
BillZ28's Avatar
Car: 84 Z28
I don't think it's going to bolt right on. I've heard some people have0 custom fabricated non-Vortec ones to fit though, but I've never seen it first-hand.
Old Feb 17, 2003 | 07:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It won't fit, don't try and mod it, it still won't work right!!
Old Feb 17, 2003 | 07:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I think it can be done. I have a vtec engine but havent checked to see if a stock manifold will work but I can check in the morning to see what will have to be done. The GM carb/vortec manifold looks to be a good piece, Im sure you can pick one up a good price.
Old Feb 17, 2003 | 08:23 PM
camaro_1983_383's Avatar
different bolt pattern.
Old Feb 17, 2003 | 08:47 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Vortec manifold
It can be done, but I wouldn't recommend it. Some circle track racers do it with success. BUT, these guys are not opposed to tearing down their motor every 2 weeks. If you want good reliability, shuck out the extra couple bucks and get the correct manifold.
Vortec = 8 bolts.
Standard = 12 bolts.
So, drilling, tapping the heads and porting the manifold to match the heads (larger openings) and a lot of jacking around for questionable results.
It really all depends what your time is worth...
Best of luck with whatever you choose.
S-D
Old Feb 17, 2003 | 09:54 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well to elaborate on what I was saying. The vortec heads only have 4 manifold bolt holes per head. The angle of the heads are the same as any SBC. The problem is the vortec manifold bolts go straight down | and standard heads are angled \. If you elgogate standard manifold bolt holes and use vortec intake gaskets I see no problems with making it work. I dont think any water passages or air passages are different. The heads dont have a EGR crossover, BFD. I will check like I said and if it can be done Ive got a spare LG4 manifold to play with of course I dont think GM was on the ball with 4 bolts holding the maifold down but eh.
Old Feb 17, 2003 | 11:28 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The intake ports simply don't match up. There will be a severe gap at the top of the port that the manifold does not reach.
Get the right manifold 'cause it WILL NOT work.
Old Feb 18, 2003 | 12:40 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Vortec heads have a raised intake port design on top of the bolt pattern issue. Some manifolds won't even cover the top of the ports on the heads. Those that do are not going to line up for jackcrap without a lot of work. Why bother with the heads to **** the power away with the incorrect intake? If you redrill the heads for the standard bolt pattern/angle, you don't have much meat for the threads. Could be stripped out fairly easily...
Just say no to Vortec heads with non-Vortec intakes...
Just comparing the port shapes on my Vortec Performer RPM to a spare standard Performer RPM I had laying around in my garage made it painfully clear that trying to screw around and use the regular intake was a darned bad idea... Too bad I didn't try laying the regular Perf RPM on the heads to see if it even covered the ports though, been curious about that.
Old Feb 18, 2003 | 01:25 AM
Ok guys thanks for all the replies. Looks like i got my anwser. I will just get the right manifold to work with my heads to save any trouble.
Thanks again, Brad
Old Feb 18, 2003 | 01:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ok I checked it today. A standard intake could fit but, the 4 bolt holes sit 1/4 of an inch higher then the manifold bolt holes, elgongating them wont work. The intake ports are close enough with gaskets but not enough to flow well. You could drill and tap new holes easily but with the intake ports missmached it would not be worth it.
Old Feb 18, 2003 | 05:34 PM
Thanks for taking the time to check that out for me. Like i said just gonna be smart and buy the right intake. Thanks for all the help guys.
Brad
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
Fast355
Dec 2, 2016 06:33 PM
theurge
Aug 21, 2015 12:46 PM
