Gear drive
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Gear drive
can i use a gear drive for an older model block, in a 88 block, im not using a roller cam, im using a hydraulic.
Also, does anyone know anything about proform gear drives, good - bad.
Kevin
Kevin
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
gear drive =
most big engine builders laugh at gear drives because of all of the lowend vibrations they transfer to the cam which will create enough cam walk that even a cam button will not help you. i would stick with an edlebrock double roller timing chain or something similar. they are generally cheaper too.
Car: 4
Engine: 6
Transmission: 5
Gear drive = monkey-spank for young children who haven't discovered going fast yet, kind of like glass-packs
True roller (not $20 "roller") timing chain = decent street setup
Belt drive = professional
Don't bother with it, it's wasted money, slows the car down. Get a Comp 3100 timing set.
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Re: Gear drive
Kevin
Kevin
