ZZ4 heads
Car: 1991 RS
Engine: 87' 350 TPI
Transmission: 700
ZZ4 heads
I just had a question about these heads. If I was to put them on my '87 IROC engine, do I have to change my manifold or anything else like that or would they be a simple bolt on.
Redddragon91
Redddragon91
Car: 4
Engine: 6
Transmission: 5
They have the pre-86 intake bolt pattern, and they lack the exhaust passages for EGR, which will cause an instant Check Engine light in your application if your car has TPI.
Other than that, they will bolt right on.
Transmission: 4L80E/4L80E
"Check engine light"?
The system isn't really feedback with regard to EGR flow. It might tend ping a little more with EGR-like advance tables, and therefore knock retart, but that won't of itself set a code.
From what I hear...
From what I hear...
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
