Rockers
Old Feb 19, 2003 | 12:57 PM
mat89RS's Avatar
Rockers
How do I adjust new rockers ??
I've search and people are writing
"screw the rocker in while to turn the pushrod , when you can't turn the pushrod easily your done"
also
"screw the rocker in until it sit tight on the rods then start the car, and unscrew until your ear the slapping and recrew it 3/4 turn.
What's the easiest way to do it ???
Old Feb 19, 2003 | 01:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Both. Either.
Do it the first way while the engine is on a stand; do it the second way, if necessary, after it's in the car and running.
You might be interested to know, new car engines are done using method #1 only. They don't disassemble motors in assembly plants and spew hot oil all over the place. They use method #1 in the engine plant, then ship them to the car assembly plant, ready to crank up and drive off.
Old Feb 19, 2003 | 01:29 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Rockers
I thought you're supposed to turn an additionaly 1/2 turn after that to pre-load the lifter?
Old Feb 19, 2003 | 02:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You are!!
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
