Special push rods?
Old Feb 20, 2003 | 07:28 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Special push rods?
I'll be using a LPE 74211 cam with .530 and .560 lift w/pro mag 1.6 rockers.
Spring pressure is 120# closed and 375# open.
I know I'll have to use an adjustable pushrod to determine correct length, but will the above mentioned spring pressure require a special type of high perf push-rod? If so, what type/brand do you guys recommend?
Old Feb 20, 2003 | 07:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll almost certainly end up with a non-stock push rod, probably .050" or .100" longer than stock. Get the Comp ones that come in .050" increments, they're the good ones. They're the ones with part numbers that start with 79.
Old Feb 20, 2003 | 07:51 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Found them in the Jegs catalog. $125 a set. Ouch!!
Oh well, it's only money!
Thx again RB.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Jsapp38
Nov 13, 2015 07:38 PM
evilstuie
Sep 24, 2015 12:04 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
