sensor? i dont know
Old Feb 25, 2003 | 12:21 AM
phil's Avatar
Car: 1984 trans am
Engine: 305 ho v8 stock
sensor? i dont know
hello all i have a 1984 trans am with the 305 ho with carb. i am trying to restore it and i have run into a problem and cant seem to find any answers so ill try you guys. there are two sensor above the thermostat that i need to replace but i dont know what they are and i would like to find out what they are before i take them out the car. the two sensors are to the piece that covers the thermostat. any help would be welcome.
thanks in advance.
phil
Old Feb 25, 2003 | 05:52 AM
ede's Avatar
ede
most likely thermal vacuum switch and not a senser. migth be a sender for a gauge or fan switch. sorry i don't know for sure about your car.
Old Feb 25, 2003 | 06:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The one with the smaller threads is the coolant temp sensor for the computer. The other one is the thermal vacuum switch for the EFE (heat riser valve).
Old Feb 25, 2003 | 11:08 PM
phil's Avatar
Car: 1984 trans am
thanks been trying to find out what those where for a while the wires are broken on both of those. could that cause a problem?
Old Feb 26, 2003 | 06:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
The CTS has wires, the other does not; it only has vacuum lines.
Here's how the vacuum lines hook up on that motor. The piece in question is the EFE TVS.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
