882 heads....
Old Feb 25, 2003 | 05:08 PM
68Beater's Avatar
882 heads....
Cant he 882 heads be shaved down from 76cc to 70cc without no problems?
Old Feb 25, 2003 | 05:29 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
ive read .006" of milling is about 1cc
so you would need to shave approx 35 thou of your heads.
alot of people say those are thin head castings and are prone to cracking.
most people wont reccomend spending time or money on these heads.
Old Feb 25, 2003 | 05:32 PM
Aron213's Avatar
Car: 88 Iroc
milling off .035 might also call for milling some off your intake to get it to line back up. You would have to mill about .060 off the intake
Old Feb 25, 2003 | 05:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are among the ultimate garbage. Throw them in the trash. No point in trying to polish a turd. It will never get shiny.
Old Feb 25, 2003 | 05:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Having said that, I'm sure someone will take up the challenge.
Old Feb 25, 2003 | 06:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They'll send it to Jet-Hot or something!!!
I wanna see the pics
Old Feb 25, 2003 | 08:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
882's are not that bad but they are the best of the worst. If they have a single exhaust crossover then the chance of them being cracked is low. If you can stick a coat hanger in both center exhaust ports and it comes out on the intake side through both, then you have a couple of paper weights. Most of those will be cracked.
If you want to go from 76 to 70cc, you have a better chance with some 993 castings. They're a heavier casting and will allow more metal to be taken off.
Old Feb 26, 2003 | 07:37 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
edit wrong post
zupmanZ28
Aug 31, 2002 09:51 AM
fast83camaro
Aug 5, 2002 08:35 AM
skipsZ28
Dec 7, 2001 08:53 PM
Cruz'N Bruz'R
Oct 27, 2001 06:58 PM
hotrodharry
Mar 13, 2001 10:49 PM
