What does a rebuild cost
Old Feb 25, 2003 | 04:36 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I was thinking about purchsing a 170,000 mile TPI motor will all accesories, wiring, and ECM for 1,000 to 1,200. I was wondering what the cost of a rebuilt would be. I would like to get a fuel injected 350 in sometime soon, but am wondering if the cost and mods needed would be worth it.
And if it would be eaiser, do you think this conversion package would be a good idea?V8 TPI Conversion Package
Old Feb 25, 2003 | 05:20 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Theres absolutely no way anybody here can tell you how much it will cost to rebuild, unless they do it. You need to call around a few shops in your area to find out.
Old Feb 25, 2003 | 05:41 PM
Aron213's Avatar
Car: 88 Iroc
a basic long block were im at will run about $1350. Thats cleaning it all, boring, doing the heads, all new parts, and assemble. You start adding options like balancing and it starts to add up!
Old Feb 25, 2003 | 08:26 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
thats a bit pricey for an engine that needs to total rebuild...
Old Feb 26, 2003 | 05:28 PM
SlowStangEater's Avatar
ditto!
Old Feb 27, 2003 | 06:28 AM
ede's Avatar
ede
no way to know till after you're done and add up the reciepts. if you're cheap, use low quality parts, do everything yourself, and skip or skimp on machine work 500 dollars is reasonable. the other side of the coin is there is no limit.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
sleprock
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
