Smog Pump Removal
Old Feb 27, 2003 | 05:08 PM
91_350TPI's Avatar
Car: Lucky Dog Racing 1992 Chevrolet Camaro Z-28
Engine: 379 cid Chevrolet race engine
Transmission: Coam TH-350 w/ transbrake
Smog Pump Removal
This is in reference to the tech article about removing the smog pump. Does the belt routing and belt sizes given in the article work universially in 3rd gen cars? Also does this proceedure require any other types of modifications? Since I believe my pump is not hooked up properly it might as well go. Thanks guys. Drive on................
Old Feb 27, 2003 | 07:08 PM
91_350TPI's Avatar
bump. Drive on.............
Old Feb 27, 2003 | 08:38 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
belt routing remains unchanged if you just remove the apump internals
it worked for me.
Old Feb 27, 2003 | 09:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
if your belts on wrong, you will know. the belt should travelfrom left to right over the alt,down and under the PS pump and over the water pump. then down and across and under the crank pulley then back up the left side all the way to the A/C pulley then over it and back to the tensioner. IS this to confusing to you
Old Feb 28, 2003 | 09:19 AM
91_350TPI's Avatar
thanks for the info guys. Drive on..............
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
