305 heads on a 350?
Old Feb 27, 2003 | 05:16 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
305 heads on a 350?
I have a 350 in my 86 TA right now and was wondering if the heads off of the old 305 would fit? I was thinking about porting and polishing them and puting them on the 350. Would i notice a power increase if i did so? Thanks!
Old Feb 27, 2003 | 05:26 PM
SlowStangEater's Avatar
Youre kidding right?
Old Feb 27, 2003 | 05:36 PM
no im not actually. IM DONT KNOW A WHOLE LOT ABOUT ENGINES OK?! AND YES I WILL LEARN, IM GOING TO AN AUTO SCHOOL THIS SUMMER. AND IM REALLY TIRED! LOL
Old Feb 27, 2003 | 05:38 PM
LOL
Its all good man
I just would suggest upgrading. The restriction would kill the potention for performance. I could be wrong though. Some guys have really made 305 heads flow........but thats on a 305.
Old Feb 27, 2003 | 05:50 PM
maybe ill just save up for some vortech heads or somethin after i deal with getting a new tranny. Thanks for the info!
Old Feb 27, 2003 | 05:56 PM
Not a problem but like I said, Im no expert either so do a search and see what you find.
Old Feb 27, 2003 | 06:08 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If your 350 is low compression with 76cc smog heads,
swapping on a set of ported 305 heads with bigger 1.94"x 1.60" valves plus some valvetrain upgrades is a good budget way to see a nice performace increase for not too many bucks.
305 heads are 58cc's and will be about 60cc's when sweeped
out for the larger valves.
Stock 305 heads flow a little less than stock low perf 350 heads.
But once ported and upgraded with larger valves they flow suprisingly well. Rivaling some out of the box aftermarket performance heads. Better than some others.
A minor pocket port will not cut it. They need a full port job and the bigger valves. Budget street replacement valves will do nicely.
You can do the required porting yourself with a die grinder and some carbide bits, stones and paper rolls. No real rocket science
to it. Get the Book by David Vizard called :How to Build Max Performace chevy small blocks on a Budget. Everything you need to know is in there. All the cylinder head info is relevant to the 305 heads.
After you're all done porting them a competant auto machine shop can provide all the nessessary machining work required.
They usually can provide the hard parts to complete the job too.
Let them know you're on a budget and get and estimate on the job.
The castings to look for are 416 for pre 86 heads and 081 for 87+ centerbolt heads.
Your compression ratio will be about 1 to 1.2 compression ratio numbers higher than with 76cc heads on a 350.
You can adjust the final cr with different thickness head gaskets,
head milling and or chamber relieving.
Old Feb 27, 2003 | 06:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, a good set of the 305 heads with some new 1.94/1.50 valves would make alot more power than your 350 smogger heads.
Old Feb 27, 2003 | 07:53 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
F-Bird'88 guided me along on my 305 port and polish job. I took a lot of pictures to help out those who also want good but inexpensive heads, so follow the link at the end of my sig.
Old Feb 27, 2003 | 08:42 PM
Marshall89ws6's Avatar
Originally posted by SlowStangEater
LOL
Its all good man
No We do not "just" port them and use them on 305s... i have ported 416s on my engine. You just need to port and polish them....install 1.94 intake valves and unshroud the chamber to match up with the 4.00 inch bore that a 350 has. It's amazing how much this subject comes up.
Old Feb 27, 2003 | 11:14 PM
Hype's Avatar
Marshall,
just curious if you have any ET's or dyno #'s with those 305 heads of yours, just curious seeing as how I have a set of LG4 heads lying around and most of the tools needed to give them a good porting, or try anyway, lol.
I figure this would put my combo at 10:1 compression, which should run on 94 octane I'm assuming...?
Thanks,
Old Feb 27, 2003 | 11:19 PM
86budgetSC's Avatar
I have been wondering the same thing.My brother in law's brother.Races stock cars.And has a set of 305 heads.That he claims are "race ported"With bigger valves.He didn't say the size of the valves.I know his stock car ran good when he had them on it.He is selling them.He isn't sure on the price yet.He said probably around 250-300.Which I figure is a good deal.He is a good guy and really smart about racing engines.
Old Feb 28, 2003 | 09:48 AM
Hey easy now,
I said I could be wrong! LOL and I was
Old Feb 28, 2003 | 01:54 PM
Engine: 305-4v
Originally posted by Hype
Marshall,
Thanks,
F-Bird'88 is "our leader" in the 305 heads wars and he has flowed his at 243 cfm at .500 lift. That supports 500 hp.
Old Feb 28, 2003 | 07:20 PM
F-BIRD'88's Avatar
Have to qualify that 500hp expectation. That is a theroretical but possible power level based on peak port flow on a perfect motor with all supporting parts and specs optumily tuned in.
You can read that as big $$$'s and lots of dyno tuning.
I am going to be testing a high compression big bracket cammed
350 with these ported 305 heads. I expect 420 to 440 hp.
(335 to 360 net rear wheel)
these actual heads flow 238cfm. The 243 cfm ones were sold to fellow third gen in Buffalo NY.
Old Mar 1, 2003 | 12:22 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Is it possible to use 350 tpi heads on a 305 tpi?
Old Mar 1, 2003 | 01:06 PM
F-BIRD'88's Avatar
Yes but the compression ratio will be lower unless you have them machined to 58cc's.
Better to install the larger 1.94valve in the 305 head and port it.
The 350 heads only flow slightly better in stock form.
Exhaust side is the same.
Old Mar 1, 2003 | 02:05 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
if you dont want to spend a whole lotta money then these heads are great.. a lot of bang for the buck lol
F-BIRD'88
how would lb9 heads run on a 406 or a 383 with a cam youd put in a 350 and a lt1 intake?
thanks
Old Mar 1, 2003 | 07:08 PM
F-BIRD'88's Avatar
Sounds like a hodge podge of parts.
Compression could be too high with stock 305 heads on a 400.
Depends on the pistons etc. But it will run.
Would need full porting, big valves and dish pistons.
Not to mention 400 block steam holes.
Old Mar 2, 2003 | 08:37 AM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
Wouldn't changing to the 305 head require higher octane gas too? Higher compression+hotter engine=detonation, right?
Old Mar 2, 2003 | 08:58 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
So for us 305 people it would be enough to change valves, right???
Old Mar 2, 2003 | 01:07 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
the 406 short block im gonna get comes with FT pistons and the compression is 11.4 with a 64 cc head and 10.1 with a 76cc head
yea i dont think it would be a good idea lol
(edit) heres the 383 just for comparo
383 has FT pistons the C/R for 64cc heads is 10.3 and with 76 cc heads is 9.2
this site doesnt give the values with different head gasket thickness though
Old Mar 2, 2003 | 04:06 PM
F-BIRD'88's Avatar
Never enough.... Depends what you want out of it.
Just changing valves is worth about 10cfm. But full porting and larger valves turns the stock head into a budget hi flow hi perf head.
Old Mar 2, 2003 | 04:13 PM
F-BIRD'88's Avatar
The 383 is going to be on the regged edge with a 64cc aluminum head.
Probabily too high for a cast iron head.
You could do some creative chamber relieving/ reshaping on a 64cc head to enlarge it some. Or shave a 76cc head to get the cr to 9.8:1 +/-...
You can compute your actual compression ratio with a simple
compression ratio program once you know the clearance specs on your motor.
go to www.download.com and get Engine CR V1.0
Old Mar 2, 2003 | 04:16 PM
F-BIRD'88's Avatar
Yes
But ; More compression doesn't mean a hotter motor, just a hotter compressed mixture in the combustion chamber.
Needs a higher octane fuel to avoid autoigntion (knock)
Old Mar 2, 2003 | 07:38 PM
Hey easy now,
haha sorry for seeming hostile i just was simply stating facts.
Old Mar 3, 2003 | 04:02 AM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
Unless you used domed pistons, but like you said its better to just upgrade the 305 heads.
Also, wouldn't there be some intake/exhaust valve shrouding when using 350 heads on a 305?
Old Mar 3, 2003 | 09:46 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah i can live with budget hi perf.
Spended all my money on a lt5 and gearbox this winter so
the 305 will be a budget one.
Old Mar 3, 2003 | 10:02 AM
Its all good cuz now I learned something
Old Mar 3, 2003 | 07:14 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
so f-bird...so a 76cc iron OR aluminum head will work...
ive benn thinkin a little and in a year or so i wanna boost this...
what kinda n/a numbers should i be looking for with a 406 mild cam a 76 cc head with 9.5 C/R
Old Mar 4, 2003 | 04:23 PM
F-BIRD'88's Avatar
What 76cc head? what camshaft? What intake? Not enough information.
"Boost this" ???
Old Mar 8, 2003 | 12:09 AM
Dane_z28's Avatar
305 heads on a 350
yes 305 heads will give your 350 a nice compression boost.
you should make shure they are H.O heads though (big valves and tighter compression chambers)
Old Mar 8, 2003 | 01:35 AM
Engine: 305-4v
Re: 305 heads on a 350
Nah, they are all the same and have 1.84" intake valves stock.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
