do i need shorter pushrods?
Old Feb 28, 2003 | 07:12 PM
87 B4Z's Avatar
im swaping some al. L98 heads and a comp cam 264 on my peanut camed 305. im having a problem with the rockers poping off and pushrods bending. do i need shorter pushrods for this higher lift cam?
Old Feb 28, 2003 | 07:57 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I don't know off-hand how much lift that cam has, but it sounds like the valve springs are binding or the valve spring retainer is hitting the top of the valve guide.
I believe the stock springs are good to .480" lift. (although some folks even have trouble at that amount of lift on stock heads)
1.6 rockers, if installed, will make the problem worse.
If you running stock rocker arms, the slot may not be long enough and the rocker could be hitting the rocker arm stud.
Proper pushrod length is determined by watching the rocker arm contact the valve tip as engine is rotated. You want the contact to stay within the center 1/3 of the valve tip.
BTW, I live near Lake Georgetown. Might be able to swing by there on Sat to check it out if you're still having trouble with it.
Old Feb 28, 2003 | 09:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What exactly are the rockers doing, that you're calling "popping off"? I have a hard time visualizing rockers behaving like, for example, a champagne bottle cork....
Old Feb 28, 2003 | 09:05 PM
87 B4Z's Avatar
i got working now. i used the old rockers arms off the 305 and that was the problem. i go tsome for a '90 vette and they worked. the problem was the old rockers didnt have a guide in the tip to hole it on the spring the vette type did.
Old Feb 28, 2003 | 09:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=163660
That was what I was referring to in here... the "rail tip" on the rocker.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
