Can someone clear this up...
Old Feb 28, 2003 | 10:31 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
My friend asked me a question the other day that kind of stumped me so I am hoping you guys can clear it up. How are electronic speedometers recalibrated? You know like when you go from 2:73 gears to 3:42s. Can anyone enlighten me?
Old Feb 28, 2003 | 11:49 PM
wyldbillracer's Avatar
i didn't change mine on my other 86 T/A, but you can go the your local speed shop and get the correct speedo pickup sensor for the trans, but i could be wrong but i think this is correct, at least it works that way for a cable driven speedo.....hope this helps, i'm sure there are others here that know more about this than me.
Old Mar 1, 2003 | 01:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Im pretty sure its just different size gears for the sensor, just like a cable driven speedo.
Old Mar 1, 2003 | 07:24 PM
trans87's Avatar
So a gear huh. Interesting. Thanks for the replies you learn something new everyday
Old Mar 2, 2003 | 09:14 AM
Vader's Avatar
Yeah, the trans-mounted VSS is gear driven, just like the cable thimbles. The dealer usually has a selection of gears that will get you close engough, ubluss you've done something drastic like changing from a 2.56 to a 4.88, in which case the drive gear on the output shaft needs to be replaced as well.
cowansauto
Apr 3, 2025 12:51 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
Mdenz3
Sep 17, 2015 08:36 AM
