T56 behind a 400: flywheel problems??
Old Mar 1, 2003 | 12:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I am trying to figure out what needs to be done to put a T56 behind a 400. I know that I can order a $360 centerforce flywheel which is made just for this, but I'd prefer to do it cheaper if possible. Summit sells a bolt on counterweight, which sandwiches inbetween the crank and flywheel, but I am nut sure how that would work, since it would move the flywheel back a little bit. I guess its not enough to matter though. Would I be able to use this bolt on counterweight with a stock LT1 flywheel? Or would I stil have to get the flywheel machined for 2 piece rear main seal?
Old Mar 1, 2003 | 10:40 AM
kevinc's Avatar
Car: 1982 Z28
The LT1 flywheel has a different bolt pattern than the 400 crank hub...you'd likely spend more $$ trying to have it machined to fit than just buying the aftermarket flywheel.
Old Mar 1, 2003 | 03:13 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i used that balancing plate that you are talking about. i got mine from goodson. i don't have a T-56 trans. it moves the flywheel forward an 1/8 of an inch at most. i have the balancing plate on my 305 flywheel. it works. i don't know how much of a beating it will take.
Old Mar 1, 2003 | 03:38 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Would an early (2 pc rear seal) T5 flywheel work with the balancing plate and a T56 clutch? Im pretty sure the bolt pattern for the pressure plate is the same.
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
sreZ28
Aug 14, 2015 07:48 PM
