need help with knock sensor?
Old Mar 2, 2003 | 12:38 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i have a ? about my knock sensor my car is not as fast as it should be im running 15.3 in the 1/4 with a L98 with the following mods.i have a niose coming from the engine its not loud really unless you get on it hard to explain i think its a wrist pin or maybe the fly wheel but is it possible im loosing power because the knock sensor hears this noise and retards the timing it kinda sounds like im getting a spark noise sometimes so my ? is can i diconnect the knock sensor ? will i have any problems besides a possible knock? is it located near the driver side exhaust intake?
air foil
under drive pulleys
b&m shift kit
flow master muffler
400 h.p. fuel pump
bbk fuel presure regulator
timing advanced to 8*btdc
hollowed out cat
new 2 1/2 ex. pipe
new mass air meter
new computer
new ignition module
new plugs
polly graphite trany mount
new m.a.f. relay
ported upper plenum
a.i.r removed
160,fan switch
180,thermostat
high performance ignition
homemade air induction
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
