when can I go full syn oil, put the motor in 3 years ago and only have 1,500 miles on
Old Mar 4, 2003 | 12:06 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a new gm 350 replacment motor in my car, i put it in 3 years ago and have only put at teh most 1,500 miles on it, I changed the only in the spring and in the fall no matter what and start the car twice during the winter and drive it a few hundred miles during the summer. I have bneen useing regular oil but I was woindering if I should switch to syn oil (mobil 1 10-30)and if I change it in the spring do i still have to change it in the fall? thanks
Old Mar 4, 2003 | 12:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's ready now.
I use AMSOIL 15W40 syn Marine oil in the '57 because it has extra corrosion inhibitors. Helps preserve engines that sit a lot.
Old Mar 4, 2003 | 05:27 AM
ede's Avatar
ede
i always wait till the first oil change, which should occur at 3000 miles for me, but for you i'd say you're past due to switch.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Aug 6, 2015 09:03 AM
NBrehm
Aug 5, 2015 07:57 PM
