heater and A/C controls
Old Mar 6, 2003 | 07:34 PM
chymos's Avatar
does anybody have a diagram of the vacuum lines that control the heater and A/C controls for an 87 'bird? I need the actual routing of the lines as installed so I can track them down and get everything working properly once I get the engine running
previous owner pulled/cut/blocked them off.....not sure as to the hot/cold lever, but the AC/vent/etc lever is stuck on defrosters
Old Mar 6, 2003 | 08:30 PM
VampireHunterC's Avatar
Good Luck!
I've asked for this before, but nobody seems to have one.
Old Mar 6, 2003 | 08:32 PM
llvll4l2c91350's Avatar
The Chilton book I got from the library for third gen Camaro and Firebird has some diagrams. If I had a scanner I'd post 'em up.
Old Mar 6, 2003 | 08:34 PM
chymos's Avatar
I'll have to get my scanner out and make a trip to the library, then........
Old Mar 7, 2003 | 06:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A diagram is not necessary. The system is too simple. It's about like looking for a diagram for a garden hose. Most of the time, if it doesn't work right, it's not hard to spot the problem.
Vacuum comes in from the engine, in a purple vacuum line at the control head; and then gets sent around by the selector switch to move the various little air doors.
Most likely, if your system is staying in Defrost, you have no engine vacuum supply, and you need to just fix that and not mess around with the control head at all. Look for a little plastic vacuum line coming through the firewall in the A/C wiring harness, just below the heater hoses. That line should hook up to the vacuum accumulator, which stores enough vacuum to hold the doors in place for a little while when you floor the gas. It gets its vacuum from the manifold.
Old Mar 11, 2003 | 05:48 PM
I know that, on mine, the vacumn cannister is missing one of the hoses. The one from the firewall, presumably to the controls, is there, but the other one is missing. Where should it connect to on the car? Engine? Carb? Where? I can get some line from Autozone if I knew where to run it!
Old Mar 11, 2003 | 06:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It should connect to a source of constant vacuum. IIRC, it's supposed to go to one of the small fittings on the base of the carb, on the rear.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
RacerM
Sep 28, 2015 04:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
buckshot63
Sep 10, 2015 09:15 AM
