Power steering removal
Old Mar 8, 2003 | 07:39 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
There is a bolt behind the fluid reservoir that screws in to the driver's side head that connects the alternator bracket. I can not get a socket in there to remove it. Does the power steering pump have to come out? The only bolt I can see on the power steering unit is the one for the pulley. Is this the only one needed to remove it?
Old Mar 8, 2003 | 09:53 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
to get at that bolt you will need to remove the pulley itself. to remove the pulley you have to get a pulley remover because the power steering pulley is pressed on. you can buy one at you local parts store for around 15 dollars.
Old Mar 9, 2003 | 06:17 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Does the center bolt actually hold the pulley there or can I remove the pulley with it in place? When I try to loosen it the pulley just spins. Sorry for the newbie question
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
