can some on tell me the real diffrence??
Old Mar 9, 2003 | 11:27 AM
icebird_1981's Avatar
in over drive and drive. and what one is better to race in and why??
thanks
Old Mar 9, 2003 | 12:00 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Depending on gearing you don't need to be in overdrive unless you are driving over 100mph while racing. For regular driving you should keep the shifter in 'overdrive' to get better mileage unless you are in stop and go traffic.
You just have to look at it like 'drive' is 3rd gear and 'overdrive' is 4th gear.
Old Mar 28, 2003 | 06:43 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
exactly...overdrive just lets teh motor cruise at higher speeds with lower rpms...thus better mileage
Old Mar 28, 2003 | 06:47 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
And you don't want to drag race in overdrive ever.
Old Mar 28, 2003 | 06:49 PM
Axle/Gears: 3:08
well if your drag racing..you should hav eenough load on the motor that wit would never get into od anyway
Attached Thumbnails can some on tell me the real diffrence??-camaro_with_new_rims.jpg
Old Mar 28, 2003 | 06:50 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
it does not matter, if you have it to the floor it goes through each gear and it will never see OD unless you go that fast, and most of the 700r4s won't let you in 4th with the throttle wide open
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
