Stealth Ram and heads combo?
Old Mar 9, 2003 | 09:30 PM
mastrdrver's Avatar
What are the biggest port heads can you run on a stealth ram without moding the intake?
Jeremy
Old Mar 10, 2003 | 02:20 PM
mastrdrver's Avatar
What about, what is the biggest port you can run with a felpro 1205 gasket? Will a 220 or 230cc intake runner work with that gasket?
Old Mar 10, 2003 | 02:52 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
For reference, AFR says to use 1205s with the 195 heads. According to Fel Pro the port size on the 1205 1.28" x 2.09". When I install my Stealth Ram, I'm going to get my AFR 190s worked to accept a 1205 gasket. (the 1204 is what AFR says to use on their 190 heads)
Old Mar 11, 2003 | 12:55 AM
mastrdrver's Avatar
Reason I was wondering, is bcuz when I do my 400 buildup, I'm going to use the Stealth Ram and wanted to run either a 220 or 230cc head, but saw a pic with the intake and the 1206 and it didnt look like it would be a good enough seal.
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
