throttle cable??? TPI to carb swap????
Old Mar 10, 2003 | 02:14 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Ok guys, what kind of cable are you guys using. can I modify the stock TPI cable, or get a special linkage stud?
I know they make one for the trans cable, but what about the throttle.
This is for a holley 4160 #3310 carb.
show pics if you got em.
thanks.
Old Mar 11, 2003 | 01:23 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
anybody?????????
Old Mar 11, 2003 | 01:42 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
i used some stud from holley that was about the same as the one that was on my qjet, just shorter
Old Mar 11, 2003 | 03:54 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I used the stock cable, it's too long but still works fine. Using Holley's throttle/TV cable bracket that Jegs sells. I used a stud from an assortment I had, works fine. Cotter pinned it on over the stud. Got a Mr gasket return spring setup and all was set with the carb crap. Also running a 3310 btw.
Old Mar 12, 2003 | 07:24 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I might try that. I already have a bracket. The adjustable one from sprectre. It seems like it will work fine. Now I just need to figure out which stud will work the best.
Got any pics of how you did it?
9192camaro
16
Feb 3, 2019 12:21 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
