valve lash
Old Mar 11, 2003 | 11:12 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
valve lash
I know this subject has been addresed many times and I have done a search and read alot of the posts. I plan on adjusting them with the engine running. What I want to know is what is the worst that can happen by not having them adjusted right to start the motor the first time. For example ; if I have any to tight could it bend or break a pushrod?, if I have any way to loose could the pushrod jump out of the lifter? Currently I have them so that there is no play between the rocker and the lifter when the lifter is down(valves closed)they can be spun between your fingers. I was able to do this with multiple rockers without turning the engine over, did I do this right? Then the ones with the lifter up where I could see it, I turned the engine over by hand until the lifter went down and adjusted those. This is the first time that I have been this far into the engine and I just want to make sure I dont screw anything up. Just let me know if I am on the right track and any assistance is greatly appreciated ! They are new pushrods, new springs, new 1.5 roller tip rockers and new cam. (hydraulic roller)
Old Mar 11, 2003 | 11:32 AM
ede's Avatar
ede
too tight could bend push rod or destroy lifters. too loose and it could fall out of the lifter. set it cold like has been posted in a 1000 other threads and then hot if you feel the need.
Old Mar 11, 2003 | 02:15 PM
KC10Chief's Avatar
Why take a chance? Just do it with the engine off. It's simple. You can take your time too. Matt
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
