Too much vacuum?
Old Mar 11, 2003 | 06:22 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Too much vacuum?
Can creating too much crankcase vacuum be bad? I had one pvc in the valve cover and the other side blocked off and it created quite alot of vacuum, can this harm anything?
Old Mar 11, 2003 | 06:28 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
will create a vacuum lock on the motor making it harder to turn the crank. also start sucking up more oil than normal. need a breather on the one side you capped off. to keep pressure equal inside the motor.
Old Mar 12, 2003 | 10:51 AM
Vader's Avatar
Actually, running the crankcase in a deep vacuum can be a good thing, other than it tends to draw hot combustion gasses into the case. The lower air mass in the case would theoretically create less aerodynamic drag on the rotating assembly. As for making it harder to turn the crank, pressure variation in a case is basically neutral, since as one piston travels downward, another is traveling upward at exactly the same rate. All eight (or six, four, etc.) cylinders balance each other in terms of crankcase pressure. I wonder how well that works on one of those 5-cylinder Vulvos. ?? Or a 3-cylinder Geo Sprint. Then again, if you have either of those, you have other issues to worry about...
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
