QUICK QUESTION.... I am sure i will leave something out
Old Mar 12, 2003 | 11:07 AM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
I am rebuilding a 350... boring it .030 over, new cam... 230/230 duration .525/.525 lift, new Pro lightning Iron heads 200 cc, with manley valves, new holley stealth ram intake, new speed pro forged pistons, all new bearings, and stuff.....
do i need to get new rocker arms, and lifters, and pushrods too?
if so what kind should i get.... I am cutting it very close on money so... think wisely for me.... thanks
Old Mar 12, 2003 | 11:35 AM
ede's Avatar
ede
roller lifters are reusable solids and hydrolics for a flat cam aren't. if you're replacing the cam with the same type you had the push rods may work, or they may be too short. best to check the length. i'd run full roller rockers but you don't have to.
Old Mar 12, 2003 | 12:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The Pro Lightning heads require +.100 longer pushrods.
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
