Say, I found an LT1 with a 6 Speed... will it...
Old Mar 11, 2003 | 12:08 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
fit easilly enough?
Its complete from computer to intake to injectors to clutch pedal.
its got like 80K miles on the motor and 6 speed. its a 95'.
guy wants $2300 for it. thinking of an LT-1 thirdgen.... should i?
Old Mar 11, 2003 | 12:22 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Sure it will fit. You need all the wiring but it sounds like you have that. Just very time consuming to redo everything.
It's been done before a lot though.
Old Mar 11, 2003 | 02:38 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
On that note, I also found an LS-1 / 6 Speed complete, as well. this ones at TGresource, however, they want $3200 for it. I heard it needs special motor mounts, however.
Old Mar 11, 2003 | 05:17 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I am pretty sure you hafta play around with acessorys to get an lt1 to fit but if you got the $ and the desire then rock on.
Old Mar 11, 2003 | 11:13 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Well let me consider, dont LT-1's have optispark? isnt that a pain to work with or somthing?
And arnt parts a bit hard to find / expensive for them?
and their compression is way up there, right?
Im just wondering if its a good thing to mess with, probably not.
what do most people with Lt-1's DO to them? do they rip them out or USE them? I know its a good motor but... better than say a procharged TPI camaro? err....
Old Mar 11, 2003 | 01:38 PM
NTChrist's Avatar
You'll probably find all the answers you need on the Motor Swap board. There's even a sticky about the 2 swaps you're asking about.
You're right about the Opti-spark. I've heard that it's prone to breakage, and expensive. There is an aftermarket replacement, but I don't remember what it was.
Old Mar 11, 2003 | 07:07 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Also check camaroz28.com , they have a large membership, mostly LT1 owners. Also there are some 3rd gen and LS1 on there. From what I read the LT1 block becomes an issue around 800-900+ rwhp. I "think" the rotating assembly is similar to a stock L98 strength wise.
A '95 LT1 makes 275 hp stock a L98 make 245 hp stock. A supercharger L98 better hurt a stock or bolt on LT1. LT1's run low 14s-high 13s stock @ 98-102 mph.
If you have another few grand to spend plus the $3200 for the LS1 I'd do that. What year is it? the newer ones I think starting in 2001 come with the LS6 intake stock "a plus". A stock LS1 will make at least 330 hp bone stock. MY roommates 02 LS1 dynoed 329 rwhp(~380 flywheel hp) and 342 rwtq with only a cat-back and air lid. He ran 13.6 @ 109(orlando spinworld) Too bad he can't drive well.
Old Mar 12, 2003 | 11:28 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Hmm i suppose it was just a passing fancy. I suppose what I REALLY Want out of the deal is the 6 speed, but those can be had for less. The guy will take $2200 for the LT-1 + 6 speed, he says, but im not sure if thats what I really need right now, I've got enough motor. I just need a drivetrain.. *sigh.
Old Mar 12, 2003 | 02:32 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
One of our sponsors had the entire 6spd swap kit with a used tranny for like $1400 or $1500 (I think it was TGresource too...) Look into that maybe. You might be able to find it cheaper on ebay or something too... I frankly don't see the money and effort being worth it with an LT1. They simply aren't powerful enough, and don't respond to mods any better than a standard 350. Takes all the bolt ons, plus a cam to get up to 300rwhp on average. As a matter of fact you throw a Stealth Ram on a otherwise stock L98 and you'll be putting down damn near the same numbers as the stock LT1...
Now an LS1 has a little bit more going for it but costs a whole lot, with full bolt ons plus a decent cam it can put out 375ish rwhp. Putting out like 300rwhp bone dead stock...
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
rudolphschenker
Sep 4, 2015 02:41 AM
