305 problem need help
Old Mar 13, 2003 | 09:31 AM
speedemon357's Avatar
I have an 86 camaro iroc-z with 65k miles on it, it has the 305 HO engine with a 5spd tranny. It is a great car and i love it, but for some reason whenever it gets warmed up it will start cutting out and bucking whenever i give it any gas. This problem has been very persistent and i have had alot of things done to try to fix it. I had new ignition put in, new fuel pump, and carb jetting adjusted. If u might know what the problem is please let me because i am really sick of this problem.
Old Mar 13, 2003 | 01:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you replace the fuel filter? What exactly was replaced for this "new ignition"? How was the "carb jetting" adjusted?
Old Mar 13, 2003 | 04:40 PM
Vader's Avatar
Demon 357,
I think I know where 5-7 is going with this one. I'll digress to his expertise, but it sounds like a lean mixture issue to me.
Old Mar 16, 2003 | 08:09 PM
I just checked with my dad and i had the fuel filter replaced already. I dont really know what my mechanic did to the carburator, but he tweaked with it and said it was working fine. So i really have no idea what is wrong with it.
Old Mar 17, 2003 | 09:33 AM
five7kid's Avatar
I would guess it is one of two things: An ignition component that suffers when it gets warm; or a weak fuel pump.
Old Mar 17, 2003 | 09:44 AM
TwistedIROC's Avatar
I will give you 2 guesses from me. The igntion module.....gets hot starts to lose spark, however this usually causes it to go ahead and die. Or this is a far shot, but it has happened to me twice the distributor has a reluctor under the rotor these are prone to crack with a lot of vibration...Those are my guesses...I would also assume that by new ignition you would have changed the obvious spark plugs and wires.
Kyle
Old Mar 17, 2003 | 11:47 AM
hmm, i already replaced the ignition module, fuel pump, and plugs and wires. Is there ne thing else it could be?
Old Mar 18, 2003 | 12:52 AM
five7kid's Avatar
Distributor cap, rotor, coil.
Old Mar 18, 2003 | 09:10 PM
Thanks alot for the tips, ill check it out.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
