Maf Help Please
Old Mar 14, 2003 | 12:20 AM
skahide's Avatar
Maf Help Please
Several months ago i remeoved the screen on my Mass Air Flow sensor. I am reading code 34 now and so i think i need a new MAF. Does that sound right? I have a 88 camaro with a 2.8L V6. Is it ok to buy a used one or best if id get a new one? Do they make high flow MAF's for Camaros? How much do they run in the price range? Thanks for the help.
Old Mar 14, 2003 | 05:24 AM
rezinn's Avatar
First of all, you don't need a high flow MAF because you couldn't possibly need more air than it can flow. Secondly, removing the screens on yours was probably a bad idea because they protect it and help it to work correctly.
Have you tried replacing the MAF relays? Do that first.
Old Mar 14, 2003 | 02:54 PM
skahide's Avatar
I know nothing about MAF's. Where are the relays? what do they look like? and what am i looking for? Thanks again
Old Mar 14, 2003 | 10:26 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
How many wires are going into your MAF? And how many screens are in it?
Old Mar 14, 2003 | 10:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Strike that, you had, I am assuming, 1 screen, three wires into the MAF? The screen was not a thin wire kind but relatively meaty? If so IIRC it is the digital thick film/frequency film type, and that screen is there for alot more than just looks. It directs the airflow to the sensor. Unless I'm mistaken (which is a possibility) you trashed your MAF.
Old Mar 15, 2003 | 11:01 AM
Vader's Avatar
Personally, I wouldn't risk a used MAF. You're lucky, since the V-6 MAFs are relatively inexpensive for some reason. I've seen them for as little as $69.00 instead of the $160.00 for V-8 MAFs.
Backing up a step or two, the 173 engine really doesn't need any extra MAF cpapacity, and as you probably discovered, de-screening it yields no results, beyond an erroneous MAF reading.
Look for a Wells SU-130 thick-film type to replace what you had, and you won't have any failure problems with it again.
Old Mar 16, 2003 | 08:39 PM
skahide's Avatar
SO if i get this Wells SU-130 thick-film, then i can place it over the end so it would be like adding the screen back in? Or would it be easier to buy a new MAF? thanks again guys
Old Mar 16, 2003 | 09:16 PM
Nasty_Bird_'90's Avatar
No no no. The 'thick film' refers to how the sensor works. It uses a film instead of a thin filament. It's not something to replace the screen that you removes. These guys are telling you to buy a new MAF. A Wells SU130 for $69.00
:lala:
Old Mar 17, 2003 | 01:47 PM
skahide's Avatar
OH OK, thank you so much guys. You've helped alot.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
