oil pressure and ticking
Old Mar 17, 2003 | 07:23 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
ok lets address the first problem first, my oil pressure usually reads high, around 60-80 today i was sittin at a stop light and it was on the red part for the "hazard zone" i acclerate and it goes to maybe 20, why is it so low now? temp guage never worked and fixed that yesterday, is that someway connected making the oil pressure guage not read right? ok net problem, i used to hear a ticking when acclerating around 3000 rpms, now i heard it acclrating around 2000 is it a valve tick? whats wrong with it? help shed some light on my problems
thanks in advance
mike
BTW: my car is a 89 camaro rs with a 2.8 v6 and a 700 r4 trans
Old Mar 17, 2003 | 08:21 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Sounds like your sending unit has gone. Check into getting another one. It couldn't hurt and besides they aren't too expensive. The ticking could be alot of things but it sounds to me like lifter tick. They will do that especially if there is a lack of oil pressure or the plungers have gone bad on a few. How many miles on the motor? Can you tell if there are any exhaust leaks?
Old Mar 17, 2003 | 08:26 PM
Transmission: autos
mileage is 149K its done the tick since before it got the low oil pressure, where is the sending unit and is it easy to install, thre is one exhaust leak in my cat converter..odd isnt it, well its there, i can see the smoke coming out of it when its cold..but its done that since bought it too, also tonight i was getttin stuff outta my hatch and i put my hand down over my exhaust and i noticed that i had oil on my hand, more than normal...
Old Mar 17, 2003 | 08:35 PM
No4NJunk's Avatar
Yeah more than normal is right! There shouldn't be ANY oil coming out of the exhaust!!! Are you sure it wasn't carbon and the water vapor?? Who does your oil changes?? How many quarts did you put in?? If the motor is overfilled oil will leak past the rear main seal and leak past the rings into the combustion chamber and out the exhaust. This is obviously very bad. Also fix the exhaust leak because its not helping things. Not sure where exactly the oil sending unit is on that car. Let me ask my brother (my memory sucks).
Old Mar 17, 2003 | 08:39 PM
Transmission: autos
my head gasket leaks a little bit, never bothered me much, i change my oil, i put in 3 1/2 qts of mobil 1 10w40 i was supprised the motor didnt take more oil than that... the exhuast leak is about to be fixed...i just dont have money now for a new motor though i do have one im gettin soon cause my trans is slowy going
Old Mar 17, 2003 | 08:44 PM
No4NJunk's Avatar
. Your kidding right?? A leaking head gasket is a big deal man!! Do you have coolant in your oil and vice versa?! How do you know its a head gasket? Did you do a compression check? This just keeps getting better.
Old Mar 17, 2003 | 08:47 PM
Transmission: autos
thats what i figure it is...seems to leak antifreeze out the exhaust in the winter, and today it seemed to be oil instead...also, there might be oil in my coolent, not sure though, its kinda brown, looks more rusty than oil
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
