Engine block dating Question
Old Mar 18, 2003 | 08:26 AM
thehurtwithin's Avatar
How's it going everyone, for once in a long while I'm asking a question! Well I just picked up a new 350 block to rebuild and I'm having a small problem, I don't know the damn year of the engine! I picked it up off a guy for 100.00 bucks, so I couldn't pass up the dael, the black is in great shape and just got back from the mach. shop, but I would really like to know the date for my own records. The guy "believes that it came out of a 79 camaro." Which does me no good. So what I really need is a list that breaks down the casting number on the block and heads, if such a list exsists. Thanks again in advance!
Old Mar 18, 2003 | 10:30 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
www.mortec.com You need the VIN number off the block for the year, though.
Old Mar 18, 2003 | 10:40 AM
Vader's Avatar
Depending on the era in which it was cast, it may have a date code:
Old Mar 18, 2003 | 02:13 PM
Cool
Thanks, I took down that info but I wasn't sure how to decode it if you will. That should help alot! Thanks!
Old Mar 18, 2003 | 08:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Post the casting number and date code. It's easy to decode.
Not that it makes even the slightest difference.... nothing about 350s changed by year, until the dipstick change in the early 80s. You don't need to decide casting dates to find out about that.
Old Mar 19, 2003 | 08:19 AM
Vader's Avatar
Except for the shallow/deep oil filter bases and the front oil gallery fitting....
Old Mar 19, 2003 | 09:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Dinner and a movie used to be a safe bet, but times have changed. Besides, not sure you'd want to date an older block...
Rear main seal type changed in 1987, but...
theshackle
Mar 5, 2017 06:37 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
