coil wiring
Old Mar 18, 2003 | 05:10 PM
quicklil87lt's Avatar
coil wiring
i just got a mallory dual point mechanical distributor, jegs coil, and my new msd wires. i just hook up the positive and negative terminals on the coil to power and ground right? if not can any tell me where they need to be hooked up. thank you
Old Mar 18, 2003 | 10:32 PM
can anyone tell me the wires i need to hook up to my coil? i need to install all this tomarrow and i need to know which wires to use. thanks if anyone can help.
Old Mar 19, 2003 | 07:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You should find an old Chiltons or something too.
+ on coil goes to ballast resistor then on to ignition switch.
- on coil goes to the wire from the points in the distributor.
RBob.
Old Mar 19, 2003 | 09:09 AM
Kaiser's Avatar
If you look on the MSD or Pertronix? websites you can find all sorts of wiring diagrams and instructions, including info on points sysems. Just ignore the stuff you don't need ...
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
