Problem with fuel sending unit
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
I could not find a fuel section so I posted the topic here. Anyway, I noticed that my high pressure sending line that goes into the sending unit is broken. The mettal tube that is welded onto the sending unit has cracked at the weld. Therefore I am loosing pressure all the time. I was wondering if you guys think it wold be ok to maybe epoxy it or to just replace it. If I replace it how much would it cost.
Thanks,
Rob
Thanks,
Rob
i wouldn't use epoxy. give gm parts a call and see if it's still avaiable, you wouldn't want anything in the fuel system to fail and spray fuel anywhere that could cause a fire, unless you have lots of insurance on the car.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
