Fan Temp Sensor?
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Fan Temp Sensor?
During an engine change, I broke the sensor lead (1 wire) for my fan temp sensor. It was brittle from being too close to the exhaust manifold.
This sensor is on the passenger side rear head, above the knock sensor.
I asked gmpartsdirect.com to give me a part number for it, but they sent me a knock sensor lead (and charged me like crazy for s/h).
Question:
Is this sensor actually for the fan temp sensor? That is what I learned from searches (I believe). I went to a parts store and they tried to sell me a dual lead sensor- like the one that goes on the front of the intake manifold for coolant temp. They said it is the "replacement" part.
Also: does anyone have the GM part number for this part?
You're help is appreciated- as always.
S-D
Question:
S-D
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
I just bought one today from carquest. It was 10.xx with tax. I was putting in the dipstick and header on that side and cracked the top of it off. Carquest part# TS82.
Car: 1991 RS
Gracias
Thanks guys-
Kwik88- I had originally tried at a NAPA.
I have a CarQuest nearby and will try them out.
Thanks,
S-D
Thanks,
S-D
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, its a switch... it should only have 1 wire going to it. Its not too hard to change... i've done it 3 times in the last 2 weeks, so i know
Car: 1991 RS
JZA
actor, actress........
As I mentioned, they were no lonoger supplting the original sensor lead I was looking for. They said it was being replaced with a 2 wire lead and matching sensor due to problems with grounding.
S-D
S-D
FormulasOnly
Sep 10, 2015 09:07 PM
