Torque Convertor
Old Mar 19, 2003 | 11:11 PM
Acidtalons's Avatar
Torque Convertor
I have my engine out, in the process of rebuilding it. So currently the torque convertor is fully accessable in the engine bay. What is required to install a new one? How hard is it?
Posted this in the Transmission forum and got not reply, so trying over here.
Old Mar 20, 2003 | 05:38 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
The converter just slides off the shaft...when installing the new one be sure to turn the converter as you put it on...it has 2 sets of teeth...it will go on so far...then turn it until it goes all the way on...
Old Mar 20, 2003 | 08:22 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yeah slides right off, when you go to put the new one on look at the shaft you will notice 2 notches on either side, on your converter you will notice 2 corrosponding notches, line em up and slide it on, you should hear 3 clicks and then its on all the way.. its pretty easy to tell when its on all the way cause if it isnt it will drip fluid. make sure ya fill your new converter with fluid before ya put it on if it isnt already filled
Old Mar 20, 2003 | 08:29 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
a little good advice, you might want to replace the front seal also while you have the converter off. Just a little insurance and save you alot of work later on.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
