sensor
Old Mar 20, 2003 | 03:32 PM
hank's Avatar
sensor
i am new a theese sensors although i a have been reading everything i can get my hands on i cant see any reference to my next question there is a sensor located paasenger side fire wall looks alot like a MAP sensor but that is on the drivers side fire wall can anyone tell what sensor is thanks:hail:
Old Mar 20, 2003 | 05:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A sensor in the firewall? are you sure?
Old Mar 20, 2003 | 06:18 PM
1986redbird's Avatar
that is the barometric pressure sensor, it measures the outside air pressure and the computer uses it to compare what the MAP sensor reads to make fuel ratio/timming changes.
Old Mar 20, 2003 | 07:02 PM
hank's Avatar
i thought it was the barometric sensor the other day i tried to buy a new one at Autozone and they said that my car did not have one Thanks
Old Mar 20, 2003 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not all cars had one... you may have a California car, but their books show a Federal car, or some one of that type of things.
It's actually the same sensor as a MAP sensor though, it's just hooked up (unhooked up?) to measure atmospheric pressure instead of the pressure in the manifold.
Old Mar 20, 2003 | 10:35 PM
ACTUALLY, theyr'e not the same sensor. the recepticle for the wiring plug has a different "KEY" position ffrom the other. if you look into the hole you can see the plastic "KEY".
I know from experiance that you cannot interchange the two sensors due to the "KEY" configuration.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
