compression
Old Mar 23, 2003 | 09:25 PM
mess21's Avatar
compression
i'm goin to be starting my engine build up as soon as i get my crate zz short block in the mail but my question is how would i figure out my compression ratio
Old Mar 23, 2003 | 10:03 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Put the piston at TDC, then use a buret and tranny fluid to measure teh volume required to fill up to the deck height. Then repeat this process on the heads with the valves in. You can now add up how much fluid it took and the volume of the head gasket. You can then plug this into a compression ratio calculator and get your ratio.
Old Mar 23, 2003 | 10:18 PM
Vader's Avatar
Like this:
Engine Calculator.xls
Old Mar 24, 2003 | 02:33 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Or this:
Compression ratio Calc
You'll need to measure the piston deck height and valve relief volume.
HardCore HotRods
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
