People with Fluidamper "Streetdampr" inside...
Old Mar 23, 2003 | 10:03 PM
Speedemon171's Avatar
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
After installing my Streetdampr harmonic balancer, I noticed the timing marker is way off from where it was on the stock balancer. The old timing marker was at the 1 o'clock position (best way of describing it) relative to the front of the balancer. I suppose my new balancer needs a timing marker in a different position. Does anyone know what position it goes in and where i could get a sufficient new timing marker.
Old Mar 23, 2003 | 10:17 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: People with Fluidamper "Streetdampr" inside...
how much is it off by?
-Brian
Old Mar 24, 2003 | 07:00 AM
Car: Camaro
Engine: 350 SBC
it says i'm advanced like 30 degrees
Old Mar 24, 2003 | 07:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your timing tab is from one of the mark location systems, but the mark on the balancer is set up for one of the other versions.
Best thing to do would be to find #1 TDC by sticking something in the spark plug hole and watching as the piston hits it while turning the motor by hand; and making your own mark on the damper with white paint or something.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LC2 TECH
Oct 13, 2015 11:53 PM
MadOTC
Oct 13, 2015 04:46 PM
