Odd chevy problem???
Old Mar 24, 2003 | 04:53 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
(Forgive me mods, its about a blazer) picked up a 82 K5 blazer the other day, with a 6.2 L diesel engine. The problem with it is where the starter bolts to the block, the block has cracked, so only one bolt holds the starter on, and it is not enough to keep it there when trying to start the engine. I still have the piece, can it or possably the starter be welded back on so I can start the thing?
I wonder if this has happened on any other 6.2 L blocks. Seems like an odd thing to happen. Thanks,
Old Mar 24, 2003 | 07:28 PM
ede's Avatar
ede
yes it can be welded
Old Mar 24, 2003 | 10:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its like a small block starter, there is the straight bolt type and the staggered bolt type. If its a staggered bolt type that you have, you can probably drill the block and use a straight bolt starter, like was done on my 350.
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
