starter problem, i think
Old Mar 24, 2003 | 08:01 PM
brimstone's Avatar
I had posted before about my car not starting at all, i turn the ignition and i hear a click, but the engine doesnt turn over. The batter connection seems to be good, the radio and everything else comes on, but not the engine. Is this the starter? Where can i get the part i need and how much is it? Someone said around $30 before, but the things i found online were in the 200s at least. Let me know what i really need to look for or if i have a different probelm. thanks.
Brimstone
Old Mar 25, 2003 | 09:57 PM
brimstone's Avatar
nobody has any insight to my problem?
Old Mar 26, 2003 | 11:57 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Does it start with a jump?
Old Mar 26, 2003 | 01:07 PM
88ROC1LE's Avatar
Does it start with a jump? Check terminals to the battery also, accessories will still come on, but a bad/loose connection can cause your problem also.
Old Mar 26, 2003 | 10:43 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
if all you connections are good then it is most likely your starter, the 200$ starters you were looking at were most likely mini hi torque/gear reduction starters.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
