I have SEVERE oil burning!
Old Mar 25, 2003 | 10:25 AM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
Ok, my car is smoking really bad. It's kinda funny because when I am at a stop light, it plumes out of my cowl hood. But anyway, it looks like the leaks are coming from the valve covers in the back and dripping onto the exhaust manifolds and burning off. But this weekend, I replaced the valve cover gaskets for the 2nd time and I KNOW I did it right. So if it's not the valve covers, where else could it be coming from??? Any help would be appreciated. Thanks!
Steve
Old Mar 25, 2003 | 10:30 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
head gasket perhaps?
Old Mar 25, 2003 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take it to the car wash, clean it off real good. Then you can see where it's coming from.
I'd bet it's the valve covers, especially if they're stock sheet-metal ones. If you didn't straighten them out around the bolt holes, then the bolt holes are "punched" through, from prior installation and maybe re-tightening; so there's no clamping force on 90% of the gasket, the only place they clamp tight is at the bolt hole.
It's possible that the seal at the back of your intake is failed, or the distributor is not tight. But odds are very high that it's the valve covers.
Also, have you by any chance removed the smog pump and its bracket?
Old Mar 25, 2003 | 12:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Make sure that the PCV system is operational.
RBob.
Old Mar 25, 2003 | 07:37 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
cleaning that motor
just to let you know to clean that motor really well have the motor warm...cover up any electronics with platic shopping bags....works well to cover up exposed air elements too..then spray the motor down with simple green ..that **** will eat the oil right off the car...real easy rinse off too...and its safe for the lawn...not the oil residue..the simple green man
Old Mar 26, 2003 | 09:41 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i spilled a little atf in my exaust manifold once, smoke poured out from under hood for like an hour, just start the car, pop the hood and watch, bound to discover something
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
