pulling studs
Old Mar 25, 2003 | 12:42 PM
1986redbird's Avatar
pulling studs
what is the best way to pull the "press-in" rocker studs out of the heads so I can install screw-in studs.
Old Mar 25, 2003 | 12:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put too much cam in the motor with too little valve spring.
Seriously, use a nut and a stack of used rocker *****. Just run the nut down and keep adding rocker ***** as the stud exposes itself.
Old Mar 25, 2003 | 12:48 PM
OK, thanks. I am going to rework the studs on my 416's when I port and polish them
Old Mar 25, 2003 | 12:53 PM
Vader's Avatar
BIRD,
That's "RedBird" for the rest of you.
Instead of using the locking nuts that were on the studs to keep the rockers on, I'd suggest getting a small supply of regular 3/8"-24 nuts and use lubricant. The self-locking nuts used with the stock rockers will be a PITA to remove with the stud out of the head. If you use grade 5 or better nuts, you can usually get 3-4 uses from them before the threads are beyond use.
If you are an electrician (or know one) who has a Greenlee hydraulic conduit punch set, the smaller size range of punches and dies uses a 3/8"-24 pull stud. If you connect the pull cylinder draw nut to the rocker stud and shim with whatever is appropriate, the studs can be pulled just about in your sleep. It's really quite easy either way, but make sure you use some sort of shim to prevent cracking the stud bosses.
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
