Cyl head dowel pins
Old Mar 25, 2003 | 08:01 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Cyl head dowel pins
On the deck surface there are supposed to be 2 dowel pins that engage the head.
I noticed there's only one dowel pin for the drivers side of my block.
I was able to get the heads on (not torqued yet) without getting the gasket ****-eyed.
Do these pins have any function other than keeping the gasket aligned?
Old Mar 25, 2003 | 09:43 PM
Vader's Avatar
Once the head is torqued into place, the dowels have little use. Still, they're cheap insurance against any possible head shifting from heat/cool cycles and resultant gasket leakage.
As long as you haven't torqued the head down, I'd be tempted to pull it and install the second dowel. In case you're wondering, the dowels I have are measuring 0.312" (5/16") x 0.590" average length (or about 19/32"). The diameter is important, but the length is not super critical since any excess will be pushed into the cooling jacket in the cylinder case. If you're really pressed, you could probably cut a shank from a 5/16" bolt and chamfer the ends to ease installation. They are not any special material.
Old Mar 26, 2003 | 05:51 AM
ede's Avatar
ede
i agree i'd want both pins i nthe block to index the head and gasket and to prevent excessive movement.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
fasteddi
Sep 2, 2015 10:29 AM
gixxer92
Sep 1, 2015 04:32 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
