Bad Gas? Or What?
Old Mar 29, 2003 | 08:43 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Bad Gas? Or What?
My Car hasn't been started since late november. I pretty much ran the gas out of it but there still was a little bit left. About two days ago i put about 6 gallons in there of new gas and it ran pretty good for a while. Today i fired it up and it ran like CRAP. Real loppy idal(More than Normal). Car wanting to die when i wouldnt constatly rev it up. And smoking an smelling like crazy. My friends said its prolly just bad gas but how come it ran fine when i first started it a couple days ago? Do the symtoms sound like bad gas or somthing else? Anything would be helpful. Thanks a lot guys..
Old Mar 29, 2003 | 09:56 PM
fanman's Avatar
I'm no expert on this subject, but maybe I can help. When you put the 6 gallons in, did you drive the car to the station? Or did you put it in from a can? If you drove the car to the station, how did it run? If it ran normal..then I wouldn't say it's bad gas. If you used a can, then when you poured it in, maybe it mixed all together (bad gas new gas). And the bad gas settled to the bottom. Like I said I'm no expert.
Old Mar 30, 2003 | 09:05 AM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
I put the gas in with a can i havent been able to drive it out of my drive way becuase i have to get insurance on it. It ran alright when it was sitting in my driveway but not half as bad as it did when i let it sit for a day
Old Mar 30, 2003 | 10:29 AM
Vader's Avatar
You may have moisture in the fuel. You may also have contaminants or debris in the tank being pumped to the filter, etc. Your post and signature don't say, but I'm guessing that you're running a carburetor, correct? That may have problems from sitting dry for six months.
So, what fuel system are you using anyway?
Old Mar 30, 2003 | 04:47 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
ya im running a holley 4160 carb. I just recently switch from TPI so what should i do differently to get it running good. Could i just clean it up and play with some things? Or is it usally very involved? Thanks for the help so far guys.
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
