Starting used motor
Old Mar 30, 2003 | 09:39 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Starting used motor
My 305 is dead and I will probably be buying a motor from a friend. The thing is the motor was running and was pulled from another car. It has been sitting for about 6 months still full of oil and all in an engine bag. The cam is a hydraulic flat tappet which I am not real educated or expirenced with. I know when new (the cam and lifters) there is a break in procedure, but should I be aware of anything before I install and start this motor for the first time. Suggestions? Thanks alot.
Old Mar 30, 2003 | 10:29 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You could use a pre oiler but 6 months isnt anything serious.
Old Mar 30, 2003 | 11:12 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thanks, I just wasn't sure about lifter bleed down with a flat tappet. Like I said the motor was running so the valve lash is already set, but I didn't know if maybe there was something extra I should do.
Old Mar 30, 2003 | 11:25 AM
Vader's Avatar
Todd,
The "extra" thing you can do is to remove the spark plugs, fully charge the battery, and crank the engine in 15 sedcond increments to distribute oil and fill the lifters. You are correct in presuming that the lifters that were left with valve spring pressure applied probably had the oil forced out of them. This is not a significant issue, but you can spin the engine a few times as described to refill them.
Old Mar 30, 2003 | 11:43 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thanks Vader, that was exactly the info I was looking for.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
L98GTA87
Aug 5, 2015 11:02 PM
